Olgu Erhan 13 Mart 2017 Paylaş 13 Mart 2017 (düzenlendi) Satin alinacak yer : ---->Mini 0801S Araç Kamerasi Bedava Kargo. GearBest --------------- 57 $ fiyatı ile park modu ve çakmak adaptörü gps tam set Videoda bol bol anlattım Main Features: 1080P super HD resolution, adopting MSC8328P ( Mstar ) chipset and Ominivision OV2710 CMOS image sensor Built-in GPS module, can remark time stamp Parking guard with katallobar installation 135 degree wide view angle USB cable data output Support HDMI output WDR wide dynamic technology, record more clear even under low-light environment One-key lock, G-sensor function, in case of emergency Maximum support 64G micro SD card ( not included ) Press OK button to take photos Built-in microphone Motion detection, more intelligent Chipset name: Mstar Chipset: MSC8328P Specification General Model: 0801S Type: Mini DVR,Car DVR with GPS Image Sensor: CMOS Storage Max External Card Supported: TF 64G (not included) Class Rating Requirements: Class 6 or Above Display Screen size: 1.5inch Screen type: LCD Power Battery Type: Safe Capacitor Battery Capacity (mAh): No Charge vay: Car charger Working Time: No Working Voltage: 5V Primary Info. Wide Angle: 100 degree wide angle Lens Size: 14mm Video/Image/Audio Decode Format: H.264 Video format: MOV Video Resolution: 1080P (1920 x 1080) Video System: NTSC,PAL Video Frame Rate: 30fps Video Output : HDMI Image Format : JPEG Audio System: Built-in microphone/speacker (AAC) White Balance Mode: Auto Functions Waterproof: No Waterproof Rating : No Loop-cycle Recording : Yes Loop-cycle Recording Time: 1min,3min,5min,OFF Motion Detection: Yes Motion Detection Distance: 5m Night vision : No Night Vision Distance: No GPS: Yes G-sensor: Yes HDMI Output: Yes WDR: Yes HDR: Yes Time Stamp: Yes Anti-shake: No Language: English,Russian,Simplified Chinese,Traditional Chinese Parking Monitoring: Yes Other Operating Temp.: 0 - 60 Deg.C Power Cable Length: 0.76m USB cable, 3.4m car charger cable, 3.53m katallobar Dimension/Weight Product weight: 0.0570 kg Package weight: 0.4360 kg Product size (L x W x H): 7.00 x 5.00 x 4.00 cm / 2.76 x 1.97 x 1.57 inches Package size (L x W x H): 14.50 x 11.00 x 9.00 cm / 5.71 x 4.33 x 3.54 inches Package Contents Package Contents: 1 x 0805P Car DVR, 1 x Car Charger, 1 x USB Cable, 1 x GPS Antenna, 1 x Clean Cloth, 1 x Sticker, 2 x Silicone Glue, 6 x Installation Gadget, 1 x Katallobar, 1 x English User Manual 13 Mart 2017 tarihinde Olgu Erhan tarafından düzenlendi 2 Yorum bağlantısı
Misafir 13 Mart 2017 Paylaş 13 Mart 2017 (düzenlendi) Emegine saglik ustam. Kafam iyice karisti. Ama bu modelde cok iyiymis. Ozellikle bu fiyata bu kalite ve 2 kit ile beraber. Yalniz yanlis gormediysem 100 derece gorus acisi var. Az degil mi? 13 Mart 2017 tarihinde Yunus Emre Çırak tarafından düzenlendi Yorum bağlantısı
Olgu Erhan 14 Mart 2017 Yazar Paylaş 14 Mart 2017 On 13.03.2017 at 21:37, Yunus Emre Çırak yazdı: Emegine saglik ustam. Kafam iyice karisti. Ama bu modelde cok iyiymis. Ozellikle bu fiyata bu kalite ve 2 kit ile beraber. Yalniz yanlis gormediysem 100 derece gorus acisi var. Az degil mi? 100 derece değil A119 ile aynı açı ile çekiyor ortalama 150 derece gibi. Karşılaştırma videosu çekmiştim. Yorum bağlantısı
