Otomobil Pas Koruyucu Spreyler
Bizim gibi eski aracı olanlar ya da pahalılık nedeniyle eskiden yüzüne bakmadığı arabasını gözü gibi sevmeye başlayanlar kış mevsiminde ve tuz buz ortamında aracı kaldırınca altta paslanabilen yerlere menteşe vida vs değişik noktalara sıkmak için güzel bir sprey var. Bu aşağıdaki sprey WD40 ile karıştırılıyor ama bunda mum da var. yani bir tabaka oluşturuyor. Bir kutusunu rıfkının altına boşalttım.
Türkiyede sadece tekzende var. Ben geçen yıl almıştım bu sene nasip oldu.  Link aşağıda..
Önemli özelliği wd40 gibi ıslak kalıp toz tutma durumu yok.
Karda oynama öncesi sıkılması tavsiye edilir.
https://www.tekzen.com.tr/boat-shield-t9-sprey-yag-2735950
Why Boeshield T-9®?
Boeshield T-9® gives superior corrosion protection and waterproof lubrication in an easy-to-apply, long-lasting formula.
Unlike other products, Boeshield T-9® cleans, lubricates and protects. One high-performance formula does it all. Whatever the application, whatever the conditions, you can count on T-9 to work harder, last longer and perform better.
On a seafaring yacht, a dusty ATV or a shower door, T-9 has you covered. T-9 endures muddy bike trails, rain-soaked back roads and salted highways. It withstands farmer’s fields, offshore oil rigs and carpenter’s workshops. For everyone from firefighters and road crews to cyclists and sailors, Boeshield T-9® is the proven solution.
True aerospace technology. T-9 was developed and licensed by global aerospace leader, The Boeing Company, to fill a need for high-performance, long-term metal protection and lubrication. T-9’s unique formulation of solvent carrier and paraffin wax coating was engineered to penetrate crevices deeply, displace moisture, dissolve minor corrosion, and leave a clean, waxy coating with lasting durability—without using Teflon, silicone, fluorocarbons, MEK, or acetone.
Cleans. T-9 attacks existing corrosion, loosens rusty parts and flushes out old lubricants. It is also extremely useful for drying wet parts, electrical motors and circuits, ignitions and connectors.
Easy, fast and clean lubrication. Spray T-9 on and wipe off the excess for immediate use. T-9 dries to a waxy, waterproof finish without leaving a sticky film to attract dirt, dust or mud.
Reaches deeper. T-9 stays liquid long enough to permeate metal crevices and seep deep inside assembled components to leave a durable protective coating that lubricates and protects—all without dismantling your equipment.
One step to long-term protection. Apply T-9 to any metal surface and let it dry. One simple step gives you a thin, penetrating film of durable, waterproof protection and lubrication that endures, month after month, or mile after mile.
Completely waterproof. T-9 dries to a clean, waxy, waterproof film that won’t wash off in rain, puddles or mud. You can rinse away sand, dust and grime with water, while leaving the lubricant intact.
Tough but safe. T-9 will not harm paint, plastic, rubber, fiberglass or vinyl. It can be used on engines, wiring and belts. T-9 is nonconductive and will not cause short circuits, so it’s also safe to use on electronics.
Perfect for coastal areas. T-9 is particularly effective for use in protecting all metals in salt water coastal areas.
Easy to remove. Use solvent or any emulsifying cleaner to remove T-9, or simply respray and allow T-9 to dissolve itself before wiping it off.
Our guarantee. Based on more than 30 years of evidence, we know that Boeshield T-9® is the best product of its type on the market. But if you can find a penetrating lubricant/protectant that is better than T-9, let us know. We’ll refund your purchase price.
